Pole Position PS test points
andrewuts1
Bettendorf, Iowa
Can anyone tell me where I should test the +5v on a pp pcb and then where to adjust it if needed on an original ps? Thanks, Andy
PP ps test points
Anyone have a picture of these test points (where they are located)? Are they clearly marked on the pcb, top board, bottom board? Where is the AR-II located? Is there a little dial on there to make an adjustment if needed? Thanks, Andy
The +5V test points are clearly marked on both boards... there should be (at least) two of them per board. The GND test points are marked as well.
The AR-II's are the power supply boards, they're on the back side of the cabinet (just below the back door). There is a small dial on them that you can adjust +5V with... I don't have a picture of that, but there should be some pictures of them online somewhere.
Before you test/adjust any voltage, clean the edge connectors first.
