Pole Position power measurement +5V line
papapopop
Osnabrueck
Hi,
after reading several threads about the great power consumption of PP, my question was : how hungry are the PP-pcbs in real.
I have one non-working pcb on my workbench (15A switcher), my Ampere-meter only has a range up to 10A, therefore I measured Video and CPU pcb as stand alone.
And now the great surprise: the CPU board takes about 3,5A
the Video board takes about 4,5A at +5,05V.
But that's only the +5V line, the +12V line I didn't check.
Maybe the pcbs takes a bit more when ths System runs.
But it was interessting. Did anyone measure it before ? I can't find.
Greets to All
post a pic of the screen with the trouble you are having. if you are running a switcher there is a good chance the board will boot. the edge connector and interconnect are big problems.
+1. I recommend making a small harness with 1/4" spade connectors on it that plug into the test point tabs on the board. The edge fingers alone really aren't capable of handling the current these things draw.
-Ian
Hi,
thanks for your interest.
With the +12V line I meant that I don't know how much the 4 amplifieres consume.
For the moment I am working at the clock circuits, cause I miss one clock signal but still waiting for new chips already ordered.
Greets to All
