Yeah, and this one looks like it's been modified to "fix" that problem.
The F2 position clearly burned up.
The orange wires that used to connect to the fuse QDs have been soldered together and taped up (visable jut above the fuse block in the photo).
This will fix the problem of blowing 25A fuses, and burning up QDs/wires/fuse holders.... but when a diode in the bridge goes short... there's no circuit protection, and something is going to have a serious meltdown (bridge, wires, xformer... who knows).
This.
I'd something in there before you run it. The same fuse holder on mine was destroyed as well. An OP put another holder in line and just left it hanging out because, I guess, he knew he'd probably have to replace it again sometime down the road.
By the way, this is a late-model Pole Position power brick, as it has the fan connector. If you're using it on an early machine with no fan, you won't use the plug next to the marquee light connection. Unless you add a fan![]()
