pole position pedal "cord and spring"
rony2211
weaverville, North Carolina
what is the thing that hooks to the gas pedal and wraps around the pot then hooks to a spring? looks like its some kind of line or something anyway its what makes the pedal work and mine broke, here can i buy one, thanks Ron
When you get the replacement, check the manual for how to run the wire... I didn't, took me forever to figure it out... then I was looking through the manual and... there it is. I didn't think they'd cover something like that in the manual, but... yep, it's there.
I second that. I was having trouble getting full speed on my game and it turned out that the pedal cable was wraped around the set screw 1 less turn that it should have been. I would never have know had I not looked at how it was suppose to be routed in the manual. The cable was just long enough that without that one wrap around the screw, the tension spring would completely release and not pull the pot around quite to full throttle.
