Klassic
working on a (new to me) pole position. lights on, monitor on, no power to the boards, tested at wire harness. swapped out both big blues with new caps, same results. the power block will pop the F3 fuse every so often.
any way to figure out if i have a bad power block/transformer, or which one of the 2 AR boards may be shot? measuring output on each AR board at the test point gave me very low readings. should be a 10.3 volt test point, was only putting out .689 + .674 on both boards.
thanks in advance.
thanks in advance.
