pole position issues
arcade5jim
Massachusetts
Hey all, I am once again looking for help with my pole position. I think the power supply is the issue but not sure. the issue started when during game play the screen would go blue and stop. I noticed one of the leads had popped off one of the fuses so I corrected that and then the game would work ok for a few minutes and then go blue again. It also sometimes loads up the game but half the background on the race course is missing. I know this game has power supply issues but I think replacing the original one is a little past my current ability so I was wondering if it is indeed a power supply issue what I need to replace on it to keep the original one working for now. As I gain more knowledge I will put in a switching one but really want to make it work for now. Any help would be great!
Hey man, you can bump your original thread. This is getting a little ridiculous:
http://forums.arcade-museum.com/search.php?searchid=2429538
Replace your fuse block, lose the quick disconnects on the 25 A fuse, make sure the 5V pots on your ARII's are set between 5.0 and 5.15. Dick Millikan out in Washington State can look at your board if you are having graphic corruption not related to the power system.
