pole position issue
tinsley
Connecticut
picked up another pole position last night. it was working on scene, but when i got it home and powered it up, all i get on the screen is random numbers. what should i even look at to troubleshoot this. it kinda looks like this on the screen (will post picture when i get home if needed):
0 0 0 3
4 0 8 0
0 0 0 0
0 3 8 0
8 0 0 0
0 0 4 0
Pole Position
I had a similar problem with mine. I ended up,
1: I Reseated all of the IC chips, cleaned the pins. And cleaned the edge connectors on the boards with Scotch Brite pad.
Recapped the ARII boards using Bob Roberts Kit.
2: I ran 16ga wire from the ARII boards to the 2 main boards. For the ground and the
5 volts. There are male spade connectos on the boards for test points.
This made a big difference. The edge connector on the Atari games are notorious for loosing ground and 5 volts.
I also removed the edge connector board and plugged the 2 cables directly into the boards.
After running the wire with the soldered on female spade connectors, I have not had a problam with the game.
I also added a 12 volt fan at the far end of the cage by the coin door to blow air across the boards toward the back of the cabinet. I attached the fan to the cage.
Good Luck
RJ
where can i get more info on the 5 volt and ground mod. i would like to this. is there a write up about how to do it anywhere online? i def dont wanyt to screw it up
Pole position mod
I PM'd you with my phone # if you want to give me a call and I can walk you threw it.
RJ
