Got a pole position II up right the problem seems to be when you first power it up after it has been setting for several mins to hours it either comes up with a blank screen a locked up screen or better yet a ram 24 error. If you shut it off with the switch or the interlock switch and turn it right back on the game will boot and play just perfect no scrambled video or sounds just screwed up at initial power up. About the game the boards were repaired a few weeks ago both ar2 boards have been gone through and the fuse block and all power brick wiring is in good shape no burnt conn ect does have both orig big blues?
