Pole Position II restoration
MrGorf
Exton, Pennsylvania
This is the restoration of my Pole Position II. Obviously non working when purchased, I further complicated things by breaking the neck of the monitor loading it into the van. It had no back door, and I forgot to make sure the monitor was secured. I'll post a little bit each night. These first pictures are how it looked when I first got it home.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Actually mines all done. I'm just finally getting around to posting the pictures, but that one does look in better shape than what I started with.
Part 2
Once I got all the parts out of the cabinet, it was time for some cleaning. Since there was no side art available, a good scrubbing with a magic eraser cleaned it up pretty good. One back corner had some damage and needed to be fixed.
attachment.php
attachment.php
I used a square as a guide for the router.
attachment.php
Made the cut with a straight cutting bit using a plunge router.
attachment.php
Bad piece removed.
attachment.php
Part 2 continued
A wood chisle squared up the corner pretty good.
attachment.php
Used a slot cutter for some biscuts to give it some support. Also mounted an additional piece of wood underneath
attachment.php
Glued the patch in place and let dry overnight.
attachment.php
Some bondo and sanding and it's ready for paint.
attachment.php
Part 2 finish
Here is the repair with primer.
attachment.php
I found a good match for the red but am still looking for the blue.
attachment.php
I sanded the front and back of the cabinet and gave it a few coats of semi flat black.
attachment.php
attachment.php
Some new leg levelers, and it's ready to be put back together.
Part 3
Here is the power brick in its original glory.
attachment.php
This is how to deal with those pesky fuses.
attachment.php
Stripped everything off and painted with hammered finish gold.
attachment.php
Bought the Atari rebuild kit from Bob Roberts, along with second big blue. Cleaned all of the wires on the transformer, crimped new molex pins on, and replaced all of the connectors. Here is the brick after re-assembly.
attachment.php
Ready for another 27 years.
attachment.php
Part 3 continued
Put the brick back into the cab, and started on the wiring harness. It had some hacks, but overall was in good shape. I cut all of the wire ties off, and basically had an AC harness and a game harness. Cleaned and replaced all of the connectors.
attachment.php
I like to start at the top and get the marquee in first. Nothing helps keep me going like seeing the lit marquee for the first time. I put a new ballast and starter on the light. Also moved the power switch from the lower back of the game to the top where I can reach it easily.
attachment.php
Also the game didn't originally have an interlock switch on the back, so I wired one in.
attachment.php
The fan was shot and needed to be replaced.
attachment.php
I cleaned and painted the PCB card cage using the same gold hammered finish paint. Here is the cage and new fan mounted in the cab.
attachment.php
Part 3 finish
The gas pedel assembly had lots of use.
attachment.php
Cleaned up with a wire wheel and a new coat of paint. Also replaced the pot, pulley, springs, and cable. Not sure what happened to the picture I had of the underside.
attachment.php
Here is a shot of it back in the cab and ready for operation.
attachment.php
Rustoleum 'Sail Blue' is a pretty close (not exact, but very close) match to the blue.
Original:
[/IMG]
Sail Blue:
Original side:
Sail Blue Side:
That's coming along nicely. I've never seen a corner, with art, cut out and patched that well.
I'd only recommend that while you have/had the stuff out of the bottom of the cabinet, run a sander over it to get the wood clean, then vac it out. That's going to be a nice game.
Joey
Part 4
Time to work on the ARII boards. As expected, they had the usual problems.
attachment.php
attachment.php
attachment.php
I replaced the burnt resistors and diodes, along with the 3055, all of the electrolytic caps, and the molex connectors.
attachment.php
attachment.php
One thing to note - I powered up the ARII boards to test them WITHOUT the CPU or videp PCB connected. Good thing, as I had forgotten to put the sense resistor back in one of the ARII boards, and the 5v was reading more like 12v. I would have smoked the board if it had been connected.
Part 4 cont.
The test panel with the volume controls and coin counter originally looked like this.
attachment.php
I used a wire wheel to remove the old paint. A couple coats of black, clean pots, and new switches, and it's ready to go.
attachment.php
attachment.php
The cardboard shroud that helped cool the card cage was missing, so a new one had to be made. After much trial and error, I'm pretty happy with the result.
attachment.php
attachment.php
Part 4 final
The coin door was missing entirely. I bought one from tokenseller, stripped it, and painted it with hammered finish black. I really like how it looks.
attachment.php
Bought some replacement coin chute/reject buttons from Bob Roberts. They really look great.
attachment.php
attachment.php
I was even able to save the original coin mech. instructions.
attachment.php
