Pole Position II Pedal [Pulley or Microswitch???]
Tombo
Administrator
Staff member
Northern, California
My PPII saga continues....
The gas pedal was non responsive. The big 'ol microswitch [switch??, macroswitch??] has taken a powder. My other machine has the pedal intact, however it is a pulley on some sort of POT. Abyone know which is factory which is mod? Just curious really. I had to rig the pulley cable to work. Somewhere along the line, the cable had been cut or snapped off.
-Tom
Re: Pole Position II Pedal [Pulley or Microswitch???]
So is the switch and actual switch? Does that mean you can only give full or no throttle? I thought I remembered PP throttle being variable. I could be wrong though.
As shipped from the factory, Pole Position and PP2 had a pulley and cable that turned a 5k pot. Star Tech Journal published a microswitch mod at least ten years ago for these games. If yours has a microswitch then it is modified.
Thanks for the heads up. I just pulled the manual and checked out the exploded view. Turns out, I attached the cable incorrectly...it works though! :) I will fix it later tonight. Also, I decided to DL the PPII manual from a link on KLOV...the dip switches on PP and PPII are completely different! Looks like I do not have to live with KM/hr after all!
Reading the correct manual helps :)
-Tom
So, bumping a 15 year old thread but can't find any information about this mod anywhere. Does anyone know where one could find information about it?
