Pole Position II ARII repair question
DocBrown
North Carolina
I'm working on my first solo repair and have a question about obtaining new components. I need to replace all the components except the ceramics on each ARII board. I have a Pole Position II stand-up conversion cabinet, and the problem I'm having is matching part numbers listed in the service manual to existing parts. Should I instead focus on the parts description and match parts that way? Again, this is my first solo repair and I'm learning most of this as I go along. I've been on Mouser, and have been told to use eBay if I need to. Any tips will be greatly appreciated!
Hi if you go in to Ian Kellogg website he sells rebuild kits for the ar2s I hope this helps you out. Bob Roberts has info on his site and there's a lot of help on here. I think johns arcade did a video on youtube on the ar2 also.
