Pole Position...i got it working but steering non responsive
I finally got around to trouble shooting my PP since 2 yrs ago....i bullet proofed it...eveything working great EXCEPT the steering....it has zero response....no tunrning at all....i removed the encoding wheel..wiped it down with 99% alcohol....i removed the couple pcb assembly and cleaned it off...reflowed all of the solder joints on the little board..check continutiy between all solder joints and continutiy from the connector that connects to it to the pins it slips on...everything seems legit....still no steering....could that little resistor on the coupler assembly pcb be bad?...i haven't tested it......EDIT: i do have the 2 blue opto lights...and my resistor tests at 153.5 ohms....no broken traces on board.
So any ideas what to address next?
Do i have to replace that little pcb?..does anyone sell them?...im going to do a search now.
