Pole Position gas pedal connection
videodan
Donor 3 years: 2023-2025
Melrose, Massachusetts
I noticed that there is a connection broken off from the assembly after the pedal stopped working. It is the black wire. I'm assuming it needs to be resoldered, but where? Can anyone show me (visually) where to make the connection to allow the pedal to work?
Thanks for any help!
there's only 3 connections on a PP gas pedal pot. 4 if you count the green ground wire. Follow the other 2 wires to the pot- they're soldered onto lugs on the pot. The black wire will go on the lug that doesn't have anything soldered to it.
