Pole Position G07
JohnV
MOORESVILLE, North Carolina
I've got horizontal rolling (G07 CBO) that I can't adjust out. This is in a Pole Position cabinet. Based on the picture, does it look like the sync is wired correctly? PPSync.jpg
No it doesn't look right
You have Sync going to +V on the 6 pin header and to -V -H on the three pin header.
Pole position is -CSYNC so try removing the purple wire from -V on the 6 pin ( pin 5 )
I've got horizontal rolling (G07 CBO) that I can't adjust out. This is in a Pole Position cabinet. Based on the picture, does it look like the sync is wired correctly? View attachment 849199
you're using the Matsushita signal plug with the 5 wires in a row with the K4900/G07 composite sync plug at the same time. there should be another 6 pin video plug in the game with just 4 wires.
Yep. There you go. I completely forgot about that in this game.
I've heard about these PP cabinets with two video plugs. Mine only has one plug, but it has this quick-disconnect (circled) that lets you choose whether to have sync signal going to the video plug pin 5. I've tried it both ways, connected and disconnected, and it won't sync. And I've tried it with and without the 3-pin connector connected. I'm starting to think my board isn't producing a sync signal. If I put in a Pi Position board, it syncs fine (with the 3-pin connected and the 6-pin's sync wire disconnected).
ah yes I forgot about that arrangement lol so the sync just isn't connected on the "Matsushita" plug if you leave the quick disconnect unplugged
I had access to the back of my cockpit today so I snapped a few photos of my G07 video connectors for you. Hope this helps.
