Pole Position cockpit filter board question
SuperGunGuru
in Memoriam
Donor 2014
Bath, Michigan
Does anyone here with a Pole Position cockpit run theirs without the filter pcb that plugs into the main board? Currently I don't have one and it seems like the back door won't shut properly without it. Obviously the filter board changes makes the edge connectors sit at a different angle that's parallel with the side wall but if you just plug them right on to the main board it looks like the wires will get pinched. I'm sure it's no big deal to get a filter board but I didn't want to add an extra point of possible failure if I can help it. Any advice is appreciated.
Mine does not have one and the door is closed.
I'll have to take another look to see what the wires are doing.
I did pick up a filter board, just haven't got back around to messing with it
Ditto. I know it's tight, but I haven't had a problem. I wouldn't mind getting the board if I find one though.
