Pole Position 5v and Ground jumper wire mod clarification, advice need - Daisy Chain?
So, I am planning on doing that 5v and ground jumper wire tonight to my Pole Position.
I have seen it done a few ways and the biggest question I have is, should I daisy chain the wires?
I was going to run one single red wire from the +5Vdc from the AR to one of the +5 lugs on the PCB. Then run a wire from that lug to the next +5 lug, etc. etc. until they are all connected to each other. And do the same for the ground (running from a ground lug on the AR to the first ground lug in my chain on the PCB). Is this ok?
I picked up 18 Gauge wire to do this. I will install a 2 pin molex between the AR and the first two connections (+5 and Ground).
Am I understanding the proper way to do this?
Thanks!
Thanks!
