Pole Position 2 sound static
Arm123
Toronto, Ontario
I got a PP machine that was dead.... Changed the HOT and the Flyback and then got garbage / scrambled graphics. Also, I check the 2 PSU's and they are working perfectly.
I had an extra PP1 board that i swapped in and the machine worked perfectly.
I then reseated and cleaned the crud off the socketed chips and the game booted up and worked. Only problem is static in the sound...
Since there is no static in the PP1 board set, im assuming that its the PP2 board set.
Any ideas what would cause that ?
