Pole Position 2 - all 0's / zero's on screen upon boot up
Klassic
Boynton Beach, Florida
what to check? game is getting 5 volts to the PCB, as test point shows.
thank you in advance.
Sounds like an issue on the CPU board to me. Look for bad sockets, failed custom IC's or corroded IC's with missing or broken pins... PP boards can be very tricky to troubleshoot if you don't have a fully working board with good IC's to swap around...
yep, i've been here before, troubleshooting an original pole position...it SUCKS.
anybody in south florida want a 90 dollar pole position ii? ha.
Mine was doing that too when I bought it. I disconnected and reconnected the ribbon cables and it worked fine after that.
