Point Blank, Random restart
Burn4Evr
Illinois
I've got a Point Blank that boots up, and you can play for a while, but it'll eventually reset on you, and come right back up. Any suggestions?
I don't see any specific pattern or time it resets. Sometimes you can get thru an entire game and it'll reset at the very end, other times it'll reset in the middle of a "match"
Power supply is the usual suspect here. It may work for sometime but will not stay the distance. Change or repair the supply BEFORE it does some damage to the board. It may not harm the board but it sure can.
It could also be an interlock switch that is not closed all of the way, if that game has one it would be on the back door. If the door is not closed proper it can do this also.
Thanks for the advice, its cheap insurance to swap out the power supply anyways, so I'll try that and see if it improves things.
