elfyhead
on both my TAF and FH, the ball shooter/plunger hits the ball significantly above center - in fact on the TAF, you can barely make the skill shot with it pulled all the way back.
i've tried adjusting them by loosening the screws and moving the assembly around in the hole, but there's just not much room for adjustment there.
i tried shimming them, but nothing worked satisfactorily.
what is the standard way to adjust the height on plungers? seems like it should be easy, but i must be missing something
