Phetishboy
1. What do you guys who route wood extensively use for fences/guides when using your plunge router?
2. Also, do you recommend drilling pilot holes before starting a slot cut in the middle of a panel, or just let the cutting bit plunge in and do the initial cut?
3. How do you cut your parallel lines? Move a fence or use a pattern?
4. On a plunge router, are bearings supposed to be at the end of the bit, or next to the collet?
