Plexi glass for mk3 control panel
kjeffery
Walcott, Iowa
Can anyone cut me the plexi for a mortal kombat 3 control panel. I dont have time or the patience as I always crack it drilling the holes. I would like all the holes to be drilled and even the holes were you screw it down on the control panel. I would need the holes drilled exact as this a dedicated machine and I need it to line up with the old button holes. Maybe 40$ shipped to some one who will do this, supplies should be less than 5$
I can do this for you but I'll need your CPO for a template. Actually, you want to use lexan-- that was originally with the CPO and its pretty much workable. If you cannot find anyone, I could do it for you, LMK!
plastic
Maybe thats why you are cracking them. Your buying the cheaper acrylic plastic that breaks if you drill to fast and also when the bit catches on a edge.
use lexan,tuffix,etc.... Ask where you buy it and tell them i want the plastic that wont crack when you drill it and if they say acrylic wont then kick them in the balls and leave.
I done hundreds in acrylic but thats were i got my gray hair from, is the pressure that you wont crack one after all the work you put into it.
