_jmfr
Pleiades and a Bubbles... need advice on router bits and repairing tmolding channel
I'm gonna document these better once they're finished however I need advice on re routing t molding grooves from where I've repaired corners.
Bubbles is easy. I'm assuming this will be suitable.
https://www.amazon.com/gp/aw/d/B000...lot+cutter&dpPl=1&dpID=31hv7tML9dL&ref=plSrch
The groove measures 1/16 on the cab.
Pleiades is confusing though. Some parts of the cab measure 1/8 and other parts is just slightly less. So what should i do ..cut it all 1/8 and buy the offset tmolding or fill it all in and recut it centered and buy bigger tmolding and trim it? Red would look sweet. If I recut a whole new slot should I cut It with the 1/16 bit? Arggg these damn Centuri cabs!
Thanks for any input. Here they are waiting for body work and paint!
