PLEASE tell me where the temp control is on my Vendo 125!!!! PLEASE!!!
vintagegamer
Donor 2024
Bear, Delaware
I have been looking for this forever!!!
It's on the cute little schem in the machine but hell if I can find it!!!
It's not by the can chute.
It's not by the coin mech.
It's not on the back of the unit.
It's not anywhere visible at all.
But the schem says it's there.
WHERE GODDAMMIT WHERE????!!!
I was mainly joking around, however, IIRC that machine there is an air vent on the bottom front of that V125.
I know on mine, the thermostat is inside the door, where you stock the soda.
Hope Ken L chimes in for you!
Post up a pic of the machine if you can...someone should be able to help you out.
Ahhhh, yes there is a red grille on the bottom front.
I thought I looked down there but I'll look again.
It's crazy!!!
Schem and machine pics.
I FOUND IT I FOUND IT!!!
Thanks to the crew at the SMC forums I finally found it!!!
The thing is on the left side under the can carriage. As shown in the pic it has no marking on it at all, just a notch that you can't turn it past (like a pot on a pcb).
There was a little play left, so I turned it further clockwise to the max. We'll see the effect it has, hopefully I turned it the right way!!
attachment.php
