modessitt
There is a big white resistor on the outside of the wall on the left. Measure the side closest to you. That is your B+. Set your meter to DC 200. Red lead on the resistor and black lead on the frame.
And make sure the black wire is connected between the tube and the neckboard anytime this is powered up.
And I often see these "dead" and come back to life simply by fixing a cold solder joint on one of the big power resistors around the horizontal width coil...
