Please help!!!! Sanyo ez20
peerless
Caveat emptor. Several Negative reviews
americus, Georgia
I was checking the +b voltage when my meter probe must have touched 2 things at once, now i have no neck glow.. Where do i start to troulble shoot this?...what do i need to check, and what should it read?
Thank you
B+ terror
Thank you
IC 601 and voltage regulator q901 are what I killed. Pricey but fixed it up. Not sure if I got lucky but it is all I needed to replace.
ez
well, nothing, i was checking it when i bumped the machine and the screen went black, no neck glow now.. ive been told to check certain things, just not what setting to use on meter and what im looking at should read.
Check your hot. Put your meter on continuity test, put your black lead to the monitor frame and put your red lead to the top of the hot.
