Please help ID this monitor 19" chassis
nate1981s
hopedale, Massachusetts
Hi,
OK I made a newbie mistake. I bought a converted UpnDown cabinet that is now Cal 50 and I wanted to recap the monitor which is in rough shape. The tag on the monitor said electrohome G07 so I though nothing of it and went to bob roberts (which was great) and bought the ultimate G07 rebuild kit. I knew something was wrong when non of the caps matched. In the pic I removed the flyback and cleaned the chassis. I put it all back and it still works fine but I want to ID the monitor so I can recap it at least.
thanks
I don't think it would even work if it had the G07 yoke. Isn't the 4900 a low impedance chassis?
It's kind of medium. They both have a similar horizontal reading (couple ohms difference). The vertical on the 4900 is about 35 ohms while the G07 is about 56 ohms. The connectors are pinned differently, but people break those things apart all the time. Not sure what result you'd get if you tried to mix and match...
