modessitt
Well, you could always send the chassis to someone with more experience so they can look at it for you to see if it is definitely a chassis issue...
If it worked with the Strikers PCB - then it would have to. It's a standard JAMMA connector, and they'd both use the same pinout. That's whay I asked way back when if the Strikers pcb still worked in it...
