BobsterD Member Joined Apr 20, 2009 Messages 276 Reaction score 2 Location New Mexico Nov 10, 2009 #1 I do not have a 10uf 100v NP cap that I need. However, I do have two 22uf 100v NP caps... If I were to run them in series, that would work correct? I think it would leave me at 11uf, which should be close enough.
kjoel New member Joined Jun 19, 2006 Messages 3,683 Reaction score 5 Location bayshore, New York Nov 10, 2009 #2 From my understanding the uf rating has to match however the voltage can be the same or higher
Talon2000 Well-known member VAPS Joined Oct 24, 2008 Messages 2,745 Reaction score 169 Location Princeton, Texas Nov 10, 2009 #3 Yeah that should be fine. most caps are at least 10% anyways. So 11 should be no problem. http://www.mouser.com/ProductDetail...=sGAEpiMZZMsCnlYck6hSqMUl0gG61HCnyRZHyCu29O0= Last edited: Nov 10, 2009
Peale Active member VAPS Joined Sep 1, 2003 Messages 3,469 Reaction score 15 Location Brattleboro, Vermont Nov 10, 2009 #4 kjoel said: From my understanding the uf rating has to match however the voltage can be the same or higher Click to expand... It's different with bipolar caps. When you run two polarized caps in series it halves the capacitance.
