I'm trying to touch up my Cleopatra playfield and went to spray it this weekend with acrylic that was cut with reducer. After the acrylic was thinned and sprayed with my Badger the coverage is horrible, at the rate its spraying it will take like 20 coats to cover anything, what am I doing wrong here?
I could use some experienced help with this one...
I'm to the point of thinking about trying to spray enamel from a spray can but don't know if I can spray on top of acrylic and what the effects will be when I try to spray clear on the whole thing.
The other thing that bothers me is that the playfield has some wear around the inserts and is showing bear wood, does this need to be filled with something or just painted over and forget it?
VB,
VB,
