wrongdon
I need to tap all of your experience here,on my playfield there is a post that takes a beating.It's just a screw in post with a small rubber on top.The problem is over the years it has been beaten back and will no longer stand up straight or screw in tight.I had some plastic wood,so i packed that in there and let it sit over night,drilled it and screwed the post in.It didnt last 5 games.
I'm guessing there is some epoxy or something i can use to fill this hole in,screw the post back in and have it take the beating it deserves.
Thank you for your suggestions
don
don
