Playchoice single monitor help needed
peerless
Caveat emptor. Several Negative reviews
americus, Georgia
Ok, i have a harness that has been hacked.. It is working on the machine just fine... How can i hook up the light gun?...the factory hookups are not there.
Thanks in advance!!!
hello
hello, thanks for the info.. the harness i have has had one edge connector replaced.. im going to have to wire it from the edge connector.. trying to figure out where to wire it..
thanks again
thanks again
Playchoice 10 (Single Monitor):
Purple wire - +5v - (R on edge connector)
Blue wire - Hit - (P on edge connector)
White wire - Trigger - (N on edge connector)
Brown & Green wire - Ground - (V & 18 on edge connector)
