Playchoice Side Art Installation
MKplayer1start
Toronto, Ontario, Canada
I got a Set of Playchoice-10 Side art coming and I'm wondering what's the right way to place it? anybody have measurements off the top and off one side?
and when installing, do you remove the monitor bolts off one side then apply the art? then put the bolts back in and remove the other side? is it safe to remove one side of bolts?
I have sideart for my dual monitor PC10 I'm waiting to replace too. I can still see an outline where the old art was, so I can get measurements tomorrow if no one has yet.
I was planning on removing the bolts because I think it's going to be a lot easier to prevent air bubbles.
When I installed my PC sideart I removed all the bolts from one side and then put them in backwards so they'd keep supporting the weight while I was working. Then when I was done the first side, I put the bolts back in properly and then moved on to the other side...
Thanks for the tip. good idea and I will definitely do the same :)
