ATM04
Just picked up a PC10 dual monitor. I noticed the displays were smashed so I started searching here. Found where the service switch needed to be off service mode so made that change. Now the both screens are black, can hear sound. Bottom play screen had a faint colored line through the middle horizontally.
I put the service switches back and the screen is still vertically smashed, but it's playable.
And what I mean by Vertically smashed is that the play area is only taking up about half the actual screen. Black at top, black at bottom.
Has anyone see this? I checked out the flow chart someone posted on here and it shows blank screen go to F301 and F302. If that's the case, and the it has a bad flyback, would the monitors be playable in service mode?
I can keep reading for solutions, but I'm hopeful someone has seen the same problem and can help.
Thanks,
Thanks,
