Playchoice games color issus
firefgtn8
Ohio
I recently picked up a Playchoice 10. I recapped and rejuvenated both monitors. Most of the games look great however several games Mario Bros. and Excitebike are all out of wack. Is this an issue with the main PCB or the smaller individual boards?
The Rush N Attack pics is good the other two are dull and you can barely see the white.
Hard to tell, but I guestion the Rush'n Attack looking good. Looks like you need to adjust your monitor. Your blue seems high and maybe other things.
Hopefully, someone else will chime in that is better at seeing monitor adjustments.
I was going to say the same thing... the blue looks really high on all 3 pics. It may just be more obvious with games you know better (i.e. SMB and Excitebike).
IIRC, the text for the score should be white/grey in Rush'n attack. The ground is grey as well.
Yeah your blue is up way to high the other colors look fine though and I play those games semi-regularly.
2600 you are right about the Rush n Attack ground/text being grey.
