inmyrem
Can someone please take a picture of the front side of their Dr. Mario Playchoice pcb for me? I bought one off the boards and it will not work. I'd like to double-check all the SL and CL locations.
Thanks!
Thanks!
But keep in mind that Dr. Mario's are very notorious for being finicky. I've had 2 different Dr. Mario pcb's... one that worked fine in my cab but not it my buddy's and the other that didn't work in my cab but did in my buddy's. Fortunately he is local so it was easy to test them. There were no other differences in our PC-10 setups... even the main pcbs were the same model.
to confirm its a bad cart
convert it to the tmnt settings
and try one of thoes chips i sent you that are compatible with tmnt
then you can confirm if its a bad cart or bad chips without mucking with a known good cart
(tip use desolder braid to remove the solder from the sl /cl pads a solder sucker works but leaves tons of solder behind and it looks messy)
