Playchoice countertop
Tball5
California
While it's not the end of the world and I've lived with it, my countertop has something called a hum bar, that I'm told. My monitor is an electrohome g07 replacement. I killed the chassis at one point a replaced it and I'm still getting the issue. I've adjusted it to hell and it still persists. After about 20 to 30 minutes of turning it on, it gets a lot better, almost unnoticeable. There is a mikes arcade color inverter because I don't have the original k7000 monitor that originally came in this unit. What am I up against? Could this be the power supply? Or a grounding issue? How can I check the power supply in my countertop? I don't know where to check is the problem, thanks in advance,
Taylor
Humbar is very common from the power supply that needs capping. I have all the kits in stock with the best quality caps. Let me know if you need help finding anything.
