PlayChoice-10 / VS - 6-in-1 Project
ebo0763
Donor 2012, 2016
NB, Canada
So I'm working on installing four loaded pc10 single monitor pcbs and two VS pcbs in one cab with a 6-in-1 switcher.
First, you can look at the pinouts with the colored wires and everything labeled. https://www.dropbox.com/s/42ta61b5acu82c0/PC10 VS Jamma - Pinout.xlsx
Slot 1 to 4 are for pc10 pbcs. Slot 5 is for a 2 in 1 switcher with one VS per slot but from the same pcb. Same thing for slot 6 but for another VS pcb.
So the VS player 1 start will be Start. VS player 2 start will be Game Select. Channel Select will be hooked up to the 2 in 1 switcher remote to change between the two games. Enter and Reset will not be used.
I'll work on this this weekend keep up updated.
BTW, I still need one pc10 single monitor pcb. I could trade a working pc10 dual monitor pcb to get a working single pcb.
Alao, can anyone tell me if audio signal M is + or -?
