Playchoice 10 power switch location?
billund
North Dakota
Hi all.
I just got a Playchoice 10 and am starting on the process of restoring it.
One question I have is, where should the main power switch be for the cabinet?
Someone pulled out the coin door lock and put the switch there. I got it out of the door, but need to know where the original location is.
Thanks so much.
James
Is it a single-monitor or a dual-monitor??? A single-monitor conversion's switch is the lower right corner on the back. A dual-monitor's switch is just below the back door in the middle.
Hi NERDtendo.
It is a dual monitor. Sounds great. I never thought to look below the big door in back. I will check for an original hole.
Thank you so much.
I will post pictures when complete
James,
A dual monitor playchoice has the power switch integrated as part of the transformer assembly.
Whom ever put that power switch in hacked it in. Throw that shit away and go find yourself the correct power/ transformer assembly. If you don't you will have a hell of a time trying to get the rest of it together.
ERIC
Original switch still there
Greetings All,
Thank you all for all the help. The original switch is still in place. Someone had rigged it so there is the other switch.
I think I will start another thread covering my overall restoration with pictures.
Thanks again.
