Playchoice 10 Hint Screen
plwagner89
Washington
What is the color of this screen supposed to be? I think it is supposed to be green but my friends is blue. Is it just adjusted wrong? I tried to get it green couldn't get it to look right. Any suggestions?
Mine is green, and from what I remember I believe they're supposed to be green. The adjustments are probably just wrong, like you said. Just keep playing with it, you should be able to get it to look alright. I still suck at adjusting monitors, so it might just take a bit of work to get it looking good; or at least acceptable if nothing else.
Assuming it's a 2 monitor system, you can swap the monitor inputs to see if it follows the monitor. If so, it's a board issue/custom bios.
Has the monitor been recapped? If not I would do that and center all the controls and start adjusting from there. Mine is green. - Barry
I just recapped it and put it back in. It was blue before the cap kit. He's not too worried about the color being blue, it actually looks pretty good. White letters and a dark blue background.
