SpiffWilkie
I got a free PC-10 off the side of the road that was complete. This afternoon I vacuumed it out a bit and tested the voltages.
The AC voltages tested at ~89, ~99, and ~118.
The +5 tested at 5.19 at the harness and the +24 tested at 21.9.
I plugged the main board into the smaller PCB, and then plugged the harness into that, but all I got was a solid blue color on the top screen and a solid greyish color on the bottom. I then noticed that the smaller PCB's connector was cracked (currently glued and clamped), so I plugged the harness directly into the main PCB (not sure if this was a good idea?) and got the same result. The monitors also look the exact same with nothing attached.
Any ideas?
On a similar note, what's the deal with the smaller PCB?
Any ideas?
