msignor
Playchoice 10 - Hard coating on sides / cracked side
Hey Guys,
I got a PC10 Single monitor in good, but rough shape.
From what I can tell, someone tried to move the cabinet and grabbed by the top of the cab by the marquee. They pulled and pulled apart the side of the cab, there is a 1/4 gap from the side to the marquee. They then, in their wisdom decided to screw it back together... wrong...using whatever size wood and sheetrock screws :-(
This caused the hard coating on the sides to ultimately crack. It is unfortunate since the sideart on the one side is PERFECT..
I plan to fill the holes with bondo, repair their repair with glue and some small blocks...
How do I finish the sides? I don't know if I want to paint it since the "glossyness" isn't stock.. Can I buy this plastic and cut it to size? Is this Laminite?
Thanks in advance,
Matt
Hey Guys,
Thanks in advance,
Matt
