Playchoice 10 guns
AlkalineJay
Donor 2013
Oak Ridge, Tennessee
So, if wired properly, will other arcade light guns work for my playchoice 10 cab? I really want/need a light gun, but the true playchoice ones are so rare, and expensive.....
To be honest, I don't know. I only have VS guns. I "think" the guns would be the same but the connections may be different. Why manufacture 2 different guns for arcade applications at the same time??
I would look at the schematics for each gun in the appropriate manuals and see if at least the basic wiring is the same. Worse case...you might smoke a $2 Zapper.
Someone with both or who has experience with both will probably come along. If anything, here is a bump!!
Par
Check out the PAR site. There is some good info about PC10 cabs and guns. Basically the PC10 has different connectors from the VS systems. The internals can be used with some adjustments if you're handy.
