playchoice-10 dual monitor
mrlizard34
Russellville, Alabama
I have recently purchased a playchoice-10 cabinet and after about 2 weeks the top monitor only displays. The time bar and the bottom only displays a blue screen. There is no sound now and the time bar doesn't display time if hit the service button. I need help troubleshooting.
I could be wrong but 10 years ago my bottom screen went blue turned out the +5 on my power supply went bad so before I knew any better I talked to a guy at a repair shops he sold me a switching power supply to replace the bad 5 volt on my game and it's worked great every since. Not sure if that helps but never hurts to check the power supply make sure it's working right
sounds like a board problem to me or a power supply problem not a monitor issue.
as stated measure your power supply voltage to the main PCB to see if its faulty.
also try and only run one cart at a time as a faulty cart can lock up a playchoice main PCB.
it sounds like you monitors are fine.
Peace
Buffett
