Playchoice 10 Countertop model keeps resetting.
ArmageddonP
West Sacramento, California
My Playchoice-10 countertop/cocktail model has this problem where it randomly resets over and over to the "wait 10 sec" screen. It makes it pretty much unplayable. It has a couple smaller other problems with a couple of the buttons, but I need to get this fixed first! What do I need to do/replace/fix to get this to stop happening! It doesn't always happen, but it will eventually!
I've tried plugging it into different wall outlets, and someone suggested buying a new power supply. Is there a way to check/set the 5v output?
My PC-10 was doing this when I got it.
I pulled the board, removed all the socketed chips and reseated them. And, I also removed all the games and then one by one installed them on the board and then tested the board. If it works with game #1 ONLY installed, then add game #2 to the PCB. Test it. If it worked with #1 and #2 installed then install #3. Test it, ETC. ETC.
Try the above and see if it works for you.
Re-seat the connections on the interconnect pcb. My countertop had the same problem every time it was opened to change games, or whenver it was moved.
