Playchoice-10 Control Panel Connectors/Pinout
elyl
Hi folks, does anyone know what type of connectors the PC-10 (dual screen) uses? There is a 12 and a 15 pin connector. It might be molex, but not sure. Also, does anyone have the pinout of them? I have the main board pinouts, but not these connectors, and being colorblind it's kind of tricky tracing the wires back!
Incidentally, I am planning to wire in a couple of original NES controller ports where the front coin slot is, and have all the inputs from the NES ports and the main control panel feed into an Arduino so you can use either the joystick or the joypads. I've not seen anyone do this before, but I'm sure someone has. Looking to match the connectors so I can keep the control panel harness stock and not have to cut and splice cables, in case I ever decide to undo my mods.
They are molex🙃 here's some pics. ✌️
