Hello all,
I just got an original Pitfall II by Sega but I'm a little stumped on this at the moment. It won't turn on - not even a buzz or a hum. What I've tested so far:
Coin door Switch
Power cord
power Supply
Those three seem to check out fine. The one component I'm not sure about is this "RFI Filter" where there is also a sticker on the inside of the cabinet above it that says "3 AMP Fuse" with a down arrow. I've not seen something like this before so I'm not sure where you can get a replacement. I assume that it can be tested the same as a fuse? It has two prongs on each side, as well as some ground wires that connect to a third prong sticking out the side (I don't have a multimeter with me at the moment so just checking on this for when I get one).
If that isn't it, what else could it be? Thanks!
Coin door Switch
Power cord
power Supply
