nmamusements
Hello,
I have a pinbot that sometimes, but not always, when the visor opens or closes, at the end of the cycle, reboots. Even when it cycles at power up, it does it once or twice then it is usually OK for a while. THen you'll be playing, and it'll do it. As I said, it doesn't do it all of the time. But, it is consistent with the fact that it reboots when the visor is at either the top or bottom of the stroke.
Here is what I have checked or tried:
Switch matrix diodes
Diode on relay board
Changed out relay
Changed out power supply
Check wiring for shorts, scrapes, etc.
Checked voltage during cycle - no drops
Thanks for any suggestions.
JB
Changed out relay
JB
