Pinbot issue: Right eject and sun flasher not working
It looks like these are on the same solenoid.. 08A / 08C.
This is my first pin, so I'm not sure if this is something simple or what, but I tested the voltage to both sides of the coil and I'm getting power. Also, I checked the resistance and it looks fine. The relay *is* firing. Sometimes the right eject (08A) DOES fire.. I'm not sure what causes it to work or stop working, but every once in a while after fiddling with it it will kick.
Any ideas of what I should check? Could the kicker itself be faulty? Is there anything anyone can recommend to help narrow down what the problem might be?
