ChaosJohn
Howdy,
I was having a problem with one of the flippers in my Pinbot. I had recently replaced the solenoids and installed flipper rebuild kits on both flippers. The one thing I didn't replace was the switches (no particular reason - I think I had replaced everything else and went to try it out and they worked fine, so I closed it up and put the switches away for later).
But recently the left flipper has been weak. So I opened it up and checked and the problem seems with the double sided switch that shuts off the flipper (don't know the proper names). It's two leaf switches back to back with a tine with a little triangular plastic spacer between them. (proper name anyone?)
The problem is that the little triangular plastic spacer partially melted, and it was dragging on the edge of one of the leaf switches (at least that APPEARS to be the problem). See attached picture for reference.
So where can I buy either the little triangular spacer on a tine or the whole double sided switch assembly. I could probably find it with google if I even knew what it was called.
Any help would be appreciated.
thanks,
John
thanks,
John
